New Machine Build CCM rails
Results 1 to 3 of 3
Thread: CCM rails
    Registered assadi's Avatar
    Feb 2015
    Default CCM rails
    Hello,
    Does anyone have tried the CCM rails for building CNC plasma ?! It seems suitable for that. According to the manufacturer
    CCM W45-15 linear module
    Positioning repeatability: <0.05MM
    Load capacity:*15KG
    Width: 40MM
    Pitch: 75MM (the linear travel distance is 75mm per one motor rotation, so if i used nema 23 motor with 1000rpm the speed is 1.25m/s)!!!
    Max length: 4*meters
    1) high accuracy
    2) customised length up to 4*meters
    3) anti-corrosion
    4) maintenance-free
    5) noiseless
    6) low vibration
    7) high reliability
    8) high durability
    9) flexible*add-ons
    10)*warranty up to*5 years
    According to this parameters is it suitable for plasma cnc ?!
    https://www.ccmrails.com
    http://www.mjunit.com/
    Can i use 3 units 2 for x axis and one for y axis ?!
    Sent from my ONEPLUS A3000 using Tapatalk
    Jul 2014
    Default Re: CCM rails
    what is the difference between ccm rails and mjunit ? Seems both sell the same products..
    May 2015
    You really need to add a 3:1 reduction ratio to get your motion back in the right range otherwise you will get a lot of jerky motion (I nearly made the same mistake as you but a couple of guys stopped me). The gear boxes will usually have a fair bit of backlash but its not hard to build a timing belt reduction that bolts onto the NEMA 23 mounting holes (which is what I did).
    Read my journey here https://forum.linuxcnc.org/30-cnc-ma...e?limitstart=0
    PS, I found the maximum speed I could get out of my cheap NEMA 23 was 750 rpm using hardware step generation from a Mesa 7i76e ethernet board and 20x microstepping. I doubt you'd get that speed out of a standard breakout board. (the Mesa board can do up to 10 Mhz). I had worked on max RPM of about 460 rpm based on my experience with an Arduino so I was very surprised!
    Rod Webster
    www.vmn.com.au
CCM rails
CCM rails
