Which THC you recommend me to buy ?!
PriceTHC or miniTHC ?! I have attached both pdf manual links, i never used THC before, i will use it with powermax 65. I have read about delay issues in thc units and torch diving ... Can you explain it ?!
As i understand the THC sensing the voltage ( measures the voltage between the plasma torch and the material being cut and trying to keep it as it set), what other methods available ?!
The cost of miniTHC and PriceTHC are the same ! What you recommend me?!
Appreciate your help
Murad
PriceTHC:
https://docs.wixstatic.com/ugd/2c759...249ea91acd.pdf
miniTHC:
http://minithc.com/pub/MiniTHC2_EN.pdf
Sent from my ONEPLUS A3000 using Tapatalk
