I want to make a 1200 x 1200 mm plasma table and i started reading about THC's and then the questions in my head started coming. Hope this forum can help clear the clouds.
Q1. Can i use my $300 plasma unit with a THC or do i have to spend $3K for anything to work with THC's.
Q2. Does a THC come with a voltage divider and do i need to match one to my plasma
Q3. Do most THC's do a good enough job at maintaining the torch height by adjusting the voltage or should i be looking for specific functionality in a THC
Q4. How bad is the arc on the electronics and is there a lot of work in getting it shielded?
# I suspect, my money should be spent on the best THC i can afford and of course plasma torch. However, i really wanted if possible to use the plasma unit i own and when i can buy a good plasma unit.
