i have FIND ...
he has 2 serial port but one is for a option fiber , and the fiber is HS on this ..
i have disconnect the serial port and adapt this and it's work :-)
Hello i need help
i'm resuming
i have a lockformer vulcan 2000 with a controller Vulcan ( D6 / NEE GABRO CUTTER II)
all the table is ok , but i want send files from profilemaster ( camduct )send with the machine to controller, i use the post processor D6 ESSI and the controller is on ESSI
i use this settings
bauds : 9600 ( exact in controller )
handbrake : RTS (exact in controller )
Data bits : 7 ( find on this forum )
stop bit : 1 ( find on this forum )
parity : even ( find on this forum )
when i launch ud6.exe and make the controller on download i have nothing he just says : WAITING and the memory on the controller don't moove and on the portmon i have only ud6.exe get_comm_status
when i go to test menu i have serial 1 in error : FIFO error and serial 2 FIFO ERROR , TX TO RX , but my cable is good is a null modem and rx is to the tx
perhaps somebody have a experience with this machine
i have FIND ...
Did you ever find the problem??? I am having similar issues on mine
