Looking for modern GoTorch
Results 1 to 5 of 5
Thread: Looking for modern GoTorch
    Oct 2016
    Default Looking for modern GoTorch
    I am needing a cnc plasma cutter about 2'x2' for cutting 16ga. I found GoTorch, but it does not seem to work on Windows10 or any modern computer. I tried to contact them with 2 questions and they never replied. Someone else told me they don't even take new orders, but perhaps that was a payment method mis-understanding. idk. So what alternatives are there? There must be some open source kit that rivals it. Suggestions?
    Oct 2016
    Default Re: Looking for modern GoTorch
    bump...
    Nov 2009
    If you buy a machine make sure it is a full system with working torch height controller and software. 16ga will require a good working torch height controller as well as an ohmic for touch off. The Gotorch was really plasmacams answer to the torchmate 2x2 which was torchmates answer to our bullet systems 2x2 and 3x2
    Oct 2016
    Thanks, I will check out the bullet system.
    Oct 2016
    So I read about Mach4 and I think this is what I am really after. A GoTorch system that uses Mach4 software. Is this coming?
