I got the machine from a Chinese company called XYZ Tech in Jinan City, Shandong Provicne, China
I have a manual for the CNC controller in English. The translations is a bit off, but given a bit of thinking, im sure you can interpret the meaning. I will try to upload it here. otherwise I will have to send the file to you via e-mail.
As for the screen shots, i will upload them as soon as i get back from China where i currently am.
As for the THC, for it to work correctly, it has to be hooked up properly to your Plasma cutter.
The THC divider board is set to receive the actual torch voltage 1:1 though it can be reset to accept 1:50 by de-soldering a jumper on the board. By your picture of the THC controller, you should have a reading of 000 for Actual Voltage. I do not see any reading. Have you hooked up your plasma cutter correctly to the Starfire controller board?
You are correct about the Arc Voltage and the HTC Delay. The center knob Arc Delay will set the delay time that starts after the plasma ark had fired. Set the delay long enough for the Plasma to cut through the metal.
If you have any further requests, you can leave them here or forward them to my e-mail address:
cergeid@yahoo.com
Regards,
