Hello,
I am Building new plasma table i have some questions before i beggin to build
i was planing to use mach3 controller but i have seen some china controllers for plasmas
like this one
HTML Code:
https://www.aliexpress.com/item/CNC-Controller-Plasma-Flame-Cutting-Machine-Accessories-Automatic-Cutting-Control-System-SF-2300S/32782059337.html?spm=2114.01010208.3.37.mUfIas&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10501_10503_10000032_119_10000025_10000029_430_10000028_10060_10062_10056_10055_10000062_10054_10059_10099_10000022_10000012_10103_10000015_10102_10096_10000018_10000019_10000056_10000059_10052_10053_10107_10050_10106_10051_10000053_10000007_10084_10118_10083_10080_10082_10081_10110_10111_10112_10113_10114_10115_10000041_10000044_10078_10079_10000038_429_10073_10000035_10121-10503_10501,searchweb201603_10,afswitch_1,single_sort_1_default&btsid=4c929410-f546-4382-a5d2-979fb864051b
i have mach3 controller and drivers 8a with nema32 1080oz but i was wondering if something costs 10 times more than mach3 is it better?
and for plasmacuter as i am on budget i was planing of using this one is it ok or is not Worth nothing and i need to whait for hypertherm machine?
HTML Code:
http://www.stahlwerk-schweissgeraete.de/de/shop/118-plasmaschneider-cut-70.html
and as i am new to plasmas and never use one
what is diference in precision cuts vs laser i Know this two cannot be measured but can plama cut with some after cut grinding acceptable or is not Worth efforts
thank you
