I am building my own 4 x 4 table and this is what I have planned.
Computer: Dell optiplex 330, windows xp. with Mach 3. Has parallel port (computer is a freebie)
Drivers: leaning towards kl-5056 but maybe leadshine mx4660. My plans are to drive the y axis with one dual shaft motor. One shaft drives the 3:1 reduction assy. w/rack and pinion and the shaft will be connected to a drive shaft running through the gantry to the opposite side, which will be connected to 3:1 reduction assy. to rack and pinion.
I'm going to build my control enclosure out of a PC case.
THC: Proma THC 150
A few questons;
I kind of hit a road block with the THC. Will a C-10 bob be what I need to make the proma work or will I need a different bob.
What else am I missing electronics wise besides the appropriate cabling and connectors?
What is your opinion on driving the y axis this way
Drawing is still being worked on. Here is what I have so far.
