There are a number of variables here, so I'll start off with the environment that the machine is installed in. First off, electrical power. You'll need one electrical distribution box for for the plasma power supply and one for the cutting machine gantry. A ground rod dedicated to the plasma cutting table.
Gas requirements: If you're cutting with air, you need an air supply with sufficient volume to supply the torch you're using. The air supply needs to be free of moisture, else you'll be going through consumables quickly. It needs to be well regulated as fluctuations in supply pressure will affect cut quality and consumable life. If you're using gas bottles, then dual stage regulators on the bottles will keep your supply pressures stable.
Table considerations: Down Draft table or water table?
What material are you cutting? Stainless? Mild Steel?
