Hi Sid
I have the same table got it used without software in Feb 2017 took a while to learn (first timer) I ordered UCANCAM and hated it !!! I later got UCANNEST (same company)
I am using a MILLER SPECTRUM 2050 with aftermarket machine torch that I love !!! and it cuts pretty/very good depending, there is no Z axis on that machine
and it doesn't cut as well as it could ; - ( I made a few parts with good results, then I BLEW THE CONTROLLER BOARD TO SMITHEREENS !!! when I attached an older style plasma cutter with HF start.............
the controller was gone but the motor drivers and motors were fine..........so instead of replacing the chinese controller I bought a WARP 9 ESS board that uses MACH 3 or 4 software, I am almost done the changeover,
I have to say that the that so far the support has been AMAZING both with the WARP 9 and MACH 3 people, but the MACH 3 still needs a cad cam program, and even though UCANNEST is better then
UCANCAM It still crashes from time to time, and randomly requires a reboot to make it work, I am trying various cad/cam programs without any huge success because they also cater to milling, lathe, etc
they have waaaaaaaaaay too many unnecessary buttons and widgets, I also have tried INKSCAPE and that seemed pretty good,.
Ralph
