Need Help! Upgrading to Pilot Arc Torch
Results 1 to 4 of 4
Thread: Upgrading to Pilot Arc Torch
    May 2015
    Default Upgrading to Pilot Arc Torch
    HI guys. I've read online that all you need to do to fit a pilot arc torch to a non pilot arc plasma machine is to attach the Pilot arc wire on the torch to ground. Which I assume means the earth clamp on the plasma machine.
    I want to change out my black Thermodynamics PCH/35 torch (black body) for a Pilot Arc Trafimet CB50 torch (Red body with guts straightened to become a machine torch) in the pic below.
    Feedback and advice would be appreciated.
    Rod Webster
    www.vmn.com.au
    Registered gregoose's Avatar
    Jun 2015
    Default Re: Upgrading to Pilot Arc Torch
    Quote Originally Posted by rodw View Post
    Hey rod, just came across your post and I was curious if you were able to make this work? I currently have a Lotos LTP6000 and was considering disabling the high frequency start and switching the torch to the trafimet. I'm currently still planning the buildand haven't budgeted for a whole new machine.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    May 2015
    No this original project kinda stalled and when I revisited it, I ended up buying an Everlast which comes with a pilot arc torch but I upgraded to a machine torch for the Everlast.
    Rod Webster
    www.vmn.com.au
    Jun 2015
    Ok, no worries, thanks for the info though. I've also been thinking of going with the everlast. Just going to have to save a little more. Thanks!
