Ok guys I finally got time to finish the scribe on the plasma table and get it working perfectly. The plasma table to took a backseat for a few months after I was laid off May 30 from my engineering job then was moved across the country to NC for my new job that I started July 9. I'll let you guess where I got a job at. On to the fun.
Parts list.
Chicago pneumatic scribe CP-9361
THK HSR20 rail
AVS-5312-120A 4-way (2 position) Use this one for a double acting cylinder
AVS-3312-120A 3-way (2 position) For supplying air to the scribe
SBC-14N Silencer cones. (Brass looking things)
MS14-14N - MALE STRAIGHT 5/PK FOR 1/4iN OD PUR/NYLON & 1/4in MNPT
#10-32 port to 1/4 OD tubing - used on the 7/16 cylinder
ME14-10N - MALE ELBOW 5/PK FOR 1/4in OD PUR/NYLON
ME14-10N - MALE STRAIGHT 5/PK FOR 1/4in OD PUR/NYLON
PU14BLU100 Blue tubing
PU14RED100 Red tubing
A07060DN 7/16 Bore double acting cylinder 6in stroke
Scribe regulator AR-323 - REGULATOR, 1/4 IN NPT, 130 PSI, GAUGE, BRACKET
Air cylinder regulator AR-322 - REGULATOR, 1/4 IN. NPT, 60 PSI, GAUGE, BRACKET
Plus a random spring from Home Depot since my air valves will only activate above 10 PSI so I needed way to up the pressure without putting to much pressure on the scribe.
Scribe regulator is run around 125 PSI and cylinder pressure will vary depending on your setup and spring, mine is at 20 PSI due to the spring and little bit of friction from the linear rail.
Baseline Sheetcam Post for MP1000 - THC- Scriber post
--*** Set these values up to suit your machine ***
--this is the distance between each torch reference in MILLIMETRES
refDistance = 250
--this is the reference feed rate in mm/min
refFeed = 500
--Put your switch offset value here in MILLIMETRES
switchOffset = 1.5
--Scriber X,Y,Z offsets in MILLIMETRES. Do not use inches here even if you want inch code
--Use the special code 'nil' on the Z axis to disable it.
--In that case no Z values will be output at all while scribing.
--e.g scriberZ = nil
scriberX = 0 Value you will change later on
scriberY = 0 Value you will change later on
scriberZ = nil This is how it should appear.
--scriber axis. Leave this as nil if the scriber is fixed to the same axis as the torch
--scriberAxis = "A"
scriberAxis = nil
--If this value is set to true then use G28 (home) for the Z reference
--Set it to false for G31 probe
refHome = true
--The cutter will slow down for corners and turn off THC below this radius
slowRadius = 10
--Minimum slow down speed.
--This is a scale factor. For instance 0.5 = 50% of the current feed rate
slowPercent = 0.4
--THC on and off codes. Use nil if you don't want THC control e.g:
-- thcOnCode = nil
-- thcOffCode = nil
--here is another example that use M667 and M666
--thcOnCode = " M667"
--thcOffCode = " M666"
thcOnCode = nil
thcOffCode = nil
--*** End of settings ***
Now lets make a alignment post to see how much offset we need in the post.
Measure you tip to the plasma table. Mine came out to around .375. I perfer to make the center of the target at (0,0) for ease of calculating offset. Remember the plate marker tool must have a tool number 100 or higher. Mine starts at 102 then goes up to according to the speed of movement.
Post the code and lets load it on Mach3. Find a empty spot on your plate with some spare room around it. I perfer to use a heavy plate so nothing moves when engraving.
Run the program. You notice the circle is away from your torch tip when your done. This is the offset that needs to be programmed into the Sheetcam Post.
To figure out the offset of the scribe the quickest and easiest we are going to use the DRO on Mach3. Center the tip of the Plasma torch over the circle.
Now we have the offset in Mach3 that we need to program into sheetcam.
Record the Values from Mach3 onto a piece of paper. Before we can enter the offsets into sheetcam we need to convert to mm so off to google to convert if you dont feel like calculating the value. P.S. 1in = 25.4 mm
Google search: "2.2262in to mm" Lazy man method.
Code editting time
refDistance = 250
refFeed = 500
switchOffset = 2.8575
scriberX = -110.99 Values I got for my table.
scriberY = 35.2425 Values I got for my table.
scriberZ = nil
--scriberAxis = "A"
scriberAxis = nil
refHome = true
slowRadius = 10
slowPercent = 0.4
-- thcOnCode = nil
-- thcOffCode = nil
thcOnCode = nil
thcOffCode = nil
When entering the values into the post, a postive value on mach3 will be a negative value for the sheetcam post and so on. Run one more test target but now your torch will shift over while the scribe is marking then center back over the target when the scribe is done. Now go have fun with your new scribe. I know I did.
