I have an old copy of Dox 10 on floppies. The floppies 1 through 5 are in the archives labelled 1 through 5.
Cheers
Hello.
I have problem with some Sattcontrol OP45's, it seems than their configuration gone wrong for some reason. As i found on the web, i need DOX10 or DOX5 software to read configuration from working PLC adn reprogram bad PLC's. I cant find DOX software anywhere on the web. Maybe someone there has this software and can share it with me?
Olafs.
Cheers
Hi password?
kockis77hotmail.com
hey is there any one who can convert dox10 to structure text?
hello guys.everybody has problem with getting correct software Dox10. i have dox10 software complete version. no need to install the software just load your project and run it. if anybody need the software contact me at info@anconsult.no
Regards
Raza
Disposeable
is it possible to load dox10 win7 ultimate 32 bit if this is possible how can i download that.
Probably not, but is possible to open e virtual machine with Win 3.11 and install on dis virtual sistem I'm not shure is easy to use serial port to make connection with PLC but I fing is possible. In my experience I have maked det on DOSBox for old games player. But unfortunally i need Master Distribution Disk for Sattcon 35 to complete installation you can help me you can send me e disket to complete my test?
Best regard Luciano
hi
dear all
could you please help me to use dox10 in the winxp , after my installing the windows get on seriall port autoexe.bat & config.sys event online mode or plc control ? very urgent thanks in advanced.
pouresmaeil.mehdi@gmail.com
hello,
i need the dox10 software for Sattcon 35.
Who has this software?
Thank you for the program it's very helpful! I case someone wonders what the default password might be: DOX10 it is
