Problem with heideinhain simulator
Results 1 to 8 of 8
Thread: Problem with heideinhain simulator
    Sep 2017
    United Kingdom
    Default Problem with heideinhain simulator
    I have little problem with my software don't know what's happen, but before everything was good, unfortunately when today I open, I cant find right panel (where is green start) all side gone.Is this my fault or I deleted some file? please see photo.
    Attached Thumbnails Attached Thumbnails Problem with heideinhain simulator-heidenhain-jpg
    Mar 2016
    Poland
    Default Re: Problem with heideinhain simulator
    U are in program editing mode, right panel is active in work modes. Use program run button, or double arrows ring button.
    Mar 2016
    Poland
    U can also use a simulation mode (the button under programming and editing mode button)
    Sep 2017
    United Kingdom
    Unfortunately, in any mode there is no right panel (blue marked) I try to reinstall and still same.
    Attached Thumbnails Attached Thumbnails Problem with heideinhain simulator-22-jpg
    Mar 2016
    Poland
    If U use simulation mode Udon't need it. U use bottom line of function keysin there. I will check at work on monday if it can be changed in MP's.
    Sep 2017
    United Kingdom
    Quote Originally Posted by steryd View Post
    I reckon, it doesn't matter, because panel disappear from any mode (Manual, hand wheel, MDI, test run, single or full run)
  7. #7
    Sep 2017
    United Kingdom
    Ok I fixed, reinstalled with different location and its come back, thanks for your help steryd anyway
  8. #8
    Mar 2016
    Poland
    U just needed to reload PLC program with default settings
