Problem Software problems with Num Flexium+
Results 1 to 4 of 4
Thread: Software problems with Num Flexium+
    Sep 2016
    United Kingdom
    Default Software problems with Num Flexium+
    Hi
    Anybody had any problems with the Num Flexium+ software?
    Mike
    Registered Russell840's Avatar
    Jul 2016
    Northern Mariana Islands
    Default Re: Software problems with Num Flexium+
    hi there
    what kinde of program? operator manual?
    HMI or PLC STL Programing?
    Sep 2016
    United Kingdom
    Quote Originally Posted by Russell840 View Post
    hi there
    Hi
    Using HMI the swap axis function was impossible to use and Num engineers agreed
    Any network / user change and flexium loses it's default programs
    Using PC link libraries fxserver had reply problems, in 50ms sweep would sometimes not reply for 1.2 seconds, scary when
    trying to control something.
    Many other minor problems, which I asked for support on and they said there no problem, then I wrote test programs to prove it
    and they eventually also 2 significant problems they came back "yes there might be a problem but no time to check".
    That was 8 months ago and I gave up with them 3 months ago
    All of the above took over a year and made my life hell, you cannot support a project when little / no support from supplier
    Mike
    Jul 2016
    Smile Re: Software problems with Num Flexium+
    Quote Originally Posted by mshsrfc View Post
    Hi
    Mike
    dear Mr Mike
    I think you are so keen to finde this Bug,Also I want to start PLC PROGRAMMING with Num Flexium + 6 and what I have is just PDF files .
    is it possiable to send me one sample of 3_AXis Milling Machine Please?
    My PLC programing experiance is just siemens LTD but in NUM Flexium+ I want to use STL stracture.
    Thanks so much
    Russell
