check the MPs it has to be there
Hello.
Does anyone know how I can use the "WRITE TO PLC KEY" command on a TNC640?
What I need is to change the safedistance on the TT tool measurement probe.
On the TNC530 i used:
"FN 17: SYSWRITE ID 1000 NR6540 IDX0 =+5" for 5mm safedistance.
But how do I do this on the TNC640?
In the plc it looks like this:
CfgTTRoundStylus (
key:="TT",
centerPos:= [
0,
0,
stylusAxis:=Z_Positive,
stylusDimension:=22,
safetyDistToolAx:=5,
safetyDistStylus:=5
it is the "safetyDistToolAx" i need to change from the nc program
-regards
Machine parameters can be read in the NC program:
DECLARE STRING QS10 = "" ;no key name, global parameter
DECLARE STRING QS11 = "CfgTTRoundStylus" ;name of configuration object
DECLARE STRING QS12 = "safetyDistStylus" ;attribute name (= parameter)
Q1 = CFGREAD( KEY_QS10 TAG_QS11 ATR_QS12 )
The machine parameters can be overwritten only the PLC program... (Module 9430, 9432, 9433)
