Hello,
After some maintenance the machine (Hermle c600) wont recognise programs when called up in the following line format, error message 'program not found'
FN 16: F-PRINT \TOOLDATA\TOOL2
"Tool 2" is a .A file which outputs via a RS232 Port, it is recognised in the NC directory and shows as a .A file
This is a proven program that worked before unknown changes were made I assume there Is an MP parameter somewhere I can change?
Cheers
