Hi Dakenskys
Did you double check the pitch of your lead screws? 2 turns per inch is a pretty coarse pitch unless this is a really big machine, or you bought some special ball screws.
Are you using any kind of feedback system on this machine, such as an encoder? Where is it mounted if it exists?
Does the axis travel quite easily? Maybe you are losing steps due to loading?
