If it is plug in, is the socket free mounted or on a circuit board?
If free mounted, I would swap it out with a current model 24vdc relay.
Hello,
I have an Eguro Nuclet 10 lathe and need to enable the collet open close utility.
Does anyone know of a CNC junkyard?
The relays are Omron G2C-232P-V
It's a DPDT 24 volt plug in with staggered pins
i build the braces that keep american teeth straight......tick tick tick
Thanks for the reply - the sockets are one of many on the M function circuit board.
I can solder some leads on relays and adapt them but I'd rather do it right if possible.
Nelson
I have come across this a few times with Omron, especially their PCT types going obsolete, fortunately I have found other makes that occasionally have the same footprint.
It can be a PITA though.
