NeoMoses
Connect the 110 thru fuse(s) and switch to the red leads (tape off the black). On the output side connect both blue leads (tape off the yellow) to your bridge retifier. Retifier to filter cap.
That connection will give you 12V out and the transformer will be under less stress than if you only use half the windings.
robotic regards,
Tom
