Is it me or B.O.B. no E-stop
Results 1 to 5 of 5
Thread: Is it me or B.O.B. no E-stop
    Dec 2003
    Boise Idaho
    Default Is it me or B.O.B. no E-stop
    I have a new PMDX 126 B.O.B it still has the jumper from e-stop to ground. when I power up the red LED should lite for 1 second then go out. the problem is it stays lit all the time with the jumper or without. i'm not yet hooked to a computer and I set all dip switches to default and config jumpers to default. Why wont the LED go out? Is it me or a bad B.O.B.
    P.S. how do you get access to all the past polls?
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: Is it me or B.O.B. no E-stop
    I don't have a PMDX 126 B.O.B
    my first thought is it could be the charge pump circuit triggering the the alarm
    I would first disable the charge pump , if it now works
    enable the charge pump and then re test to and check your control software is sending a 10Kh signal to the correct pin?
    John
    PS
    just read its not connected to a computer
    Dec 2003
    Boise Idaho
    Thanks for your reply John-100
    The default dip switch already has the charge pump turned off. and the manual says the charge pump will not affect the operation of the e-stop. Good idea though
    My P.S. was asking where on CNCZONE can I go to find all the results of all the past polls taken on this site. its hard to search when I don't know the subject of all the polls.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Looks like if you search for "poll", it'll list them all, with a few other threads thrown in as well.
    As for the bob issue, give PMDX a call tomorrow. They have excellent support.
    UCCNC 2017 Screenset
    Dec 2003
    Quote Originally Posted by onthemarc View Post
    Why not just do a subject search?
    Also the manual does confirm that the E-stop is active high, if the input is connected to common (GND) it should enable the system, i.e. E-stop OFF.
    Could be a board problem?
