Go to your FSSB page and see what drives the CNC sees. If you look at the drives look at the segment LED on all of the drives.
fanuc 310-I model A
Machine keeps throwing this alarm code don't really know much about it and cannot get it to reset. throwing in the towel. Not sure if its a bad optic cable or psu. Any insight would be great!!! thanks in advance.
- Need Help!- 570 insufficient lubrication oil alarm
- Problem- insufficient memory
- Insufficient FeedRate
- Need Help!- DNC insufficient memory?
Control has windows as the os and before it alarmed out I received an error window through Windows. I didnt get any picture of the error window not sure if that helps with trouble shooting or not. Segment lights are the leds that show numbers? If the are the first 2 show up as lines x y z w drives are not lit at all.
