If your voltage is consistently high, you could take a few turns off of the secondary and reduce the output voltage. Not sure how many you would need to take off, but you can measure the input voltage and the output AC voltage and calculate the Turns Ratio TR = ACVin/ACVout. DCVout = ACVout * 1.414 From this you could figure out how many turns to remove to get you desired max DCV out.
