8 conductor wire, 4 - 12 gauge & 4 - 16 gauge
Results 1 to 5 of 5
Thread: 8 conductor wire, 4 - 12 gauge & 4 - 16 gauge
    Jun 2011
    Default 8 conductor wire, 4 - 12 gauge & 4 - 16 gauge
    I'm working on sourcing components to hook up a Colombo spindle. The spindle needs a specialized power cable.
    8 conductors. 4 - 12 gauge and 4 -16 gauge.
    Describes like this...
    Power Cable (3+T) x 4.0 mmq + 2x1+2x1.5 mmq SK
    Includes 12 Gauge Wire for Primary Conductors - Outside Diameter: 16.0mm
    I was quoted $45 a meter. Hoping to find it a bit cheaper.
    Dec 2003
    Default Re: 8 conductor wire, 4 - 12 gauge & 4 - 16 gauge
    Check out flexible conduit, either plastic or metallic, and MTW/TEW single conductor stranded.
    Usually best if you twist the conductor pairs together as much as possible.
    ,Al.
    Jun 2011
    Quote Originally Posted by Al_The_Man View Post
    ,Al.
    Not sure if that would work. The spindle takes a specialized connector.
    Attached Thumbnails Attached Thumbnails 8 conductor wire, 4 - 12 gauge & 4 - 16 gauge-20171109_174053-jpg   8 conductor wire, 4 - 12 gauge & 4 - 16 gauge-20171109_174021-jpg
    Dec 2003
    I know there are threaded adapters from MS connectors to conduit, if they use the same threads as MS then that would be an option.
    Dec 2003
    This is the ones i have used in the past, I bet the smaller one is the same as MS.
    Attached Thumbnails Attached Thumbnails 8 conductor wire, 4 - 12 gauge & 4 - 16 gauge-tandb_ms-jpg
