That shows 600v input, Canadian standard, probably a retro-fit by Stan-Canada.
If so obtain a 480 to 600v 3 phase transformer.
Did you just buy this?
Wiring done on Ryazan CNC Lathe, input power is 480 3ph.
I believe I need a multi-tap transformer 112.5 kva with the various outputs as shown on page 1 of the attached
Where can I locate one? GE FANUC OTC Control
- Problem- Multi Pass multi-insane?
- Multi Cam MG 308
Yes, wired up except for transformer and yes it came from Stan Canada
No internal transformers in magnetic cabinet, local "expert" said get a multi-tap to suit
So why was the transformer 'missing'?
