- NCT90T serial connector wiring
Need help to figure out the correct pinout for DB25 RS232 serial connector in NCT 90T operating system.
Attached is a picture from the connector back side with pin numbers included.
Does anybody have a wiring diagram for this? Sofar I have not found one.
How to wire to DB9 serial connector?
The machine is Gildemeister 280 NEF lathe with NCT 90T operating system
- You may not post replies
- You may not edit your posts
Forum Rules
