18 gauge would probably be fine for those motors. I would not go any bigger than 16 guage.
Personally, I don't believe that you need to use shielded wire from your drives to your steppers.
The VFD wire to the spindle MUST be shielded.
I am working on my first table had planned to use shielded cables for pretty much everything I could. That was until I tried to locate 12/4 stranded shielded wire. It feels like it doesn't exist. The fact this isn't commonly available leads me to believe I'm doing something silly, and it's not what I should be using.
The steppers are Nema 34 3.5A 60V and the longest run will be somewhere around 30 feet. I was leaning towards 12AWG stranded (seems to be readily available and often sold as 12/4 speaker cable) figuring voltage drop would be minimal but then I got caught up in the search of shielding.
Is it common to skip the shielding on your stepper and VFD wiring and only use shielded for your low voltage sensors? I suppose I'm most worried about the interference introduced by the VFD. It's a 3kw 3ph spindle. I've seen a few builds where builders mount the inverter to the back of their Z-axis, perhaps it's to avoid this dilemma entirely.
Please share your thoughts! Thanks in advance, happy to be part of CNCZone!
UCCNC 2017 Screenset
Thanks for your input Gerry! Now the hunt for the correct gauge wire for my VFD begins.
