CENTROID controls?
I have a Supermax ycm 40 around 87 model. There is a breakout board inside the panel on the back of the machine. I have been trying to find out what voltage powers that. Thank you in advance
- New Machine Build- Help deciding which breakout board or driver board etc to use!
- Need Help!- BREAKOUT BOARD INTERFACE BUFFER BOARD
- Need Help!- need help with a breakout board
- Breakout board, Relays on board?
CENTROID controls?
Still has its servos? what kind? other inputs? coolant? encoders and limit switches run thru this box? some pics or names on box/motors/encoders.want to keep
existing control as much as possible or change out to more modern control or?
EDIT here is a good comparison
http://www.cnczone.com/forums/contro...-software.html
This isn't giving me notifications when I get your replies. My direct email is brmachineshop@yahoo.com. I converted the machine to run mach3 a few years ago. My phase converter went out recently and I installed a variable speed drive that has single phase input and three phase output. However I removed the spindle control buttons to mount the variable speed drive. There is a breakout board in the back panel that I think needs power but I cannot find any documentation on how many volts it requires. The number on the board is PCB 805 901-182 REV.
I don't have anything specific to that machine, but is where the 3 ph power originally entered the machine?(ie repowering the entire machine?)
