Supermax ycm 40 breakout board
Results 1 to 7 of 7
Thread: Supermax ycm 40 breakout board
    Aug 2010
    united states
    Default Supermax ycm 40 breakout board
    I have a Supermax ycm 40 around 87 model. There is a breakout board inside the panel on the back of the machine. I have been trying to find out what voltage powers that. Thank you in advance
    Oct 2016
    Default Re: Supermax ycm 40 breakout board
    CENTROID controls?
    Aug 2010
    united states
    Quote Originally Posted by jimairth View Post
    CENTROID controls?
    Originally it had an anilam crusader M control on it
    Oct 2016
    Still has its servos? what kind? other inputs? coolant? encoders and limit switches run thru this box? some pics or names on box/motors/encoders.want to keep
    existing control as much as possible or change out to more modern control or?
    EDIT here is a good comparison
    http://www.cnczone.com/forums/contro...-software.html
    Aug 2010
    united states
    This isn't giving me notifications when I get your replies. My direct email is brmachineshop@yahoo.com. I converted the machine to run mach3 a few years ago. My phase converter went out recently and I installed a variable speed drive that has single phase input and three phase output. However I removed the spindle control buttons to mount the variable speed drive. There is a breakout board in the back panel that I think needs power but I cannot find any documentation on how many volts it requires. The number on the board is PCB 805 901-182 REV.
    Oct 2016
    I don't have anything specific to that machine, but is where the 3 ph power originally entered the machine?(ie repowering the entire machine?)
  7. #7
    Aug 2010
    united states
    I think it did. I may have a headache on my hands trying to get everything else powered up now
