No, it won't. You'd need to use a Mach3 compatible motion controller, like the UC100 from CNC Drive.
I already have a Arduino (GRBL) based controller, but i bought a Mach3 compatible kit from eBay ( 5Axis CNC Breakout Board Set + Display + KeyPad For MACH3 CNC Control Software | eBay ) to evaluate while i build my CNC router. it only occurred to me after i bought it, my laptop does not have a parallel port. so my question is, will Mach3 run the hardware if i use a USB to Parallel Port converter?
Thanks in advance for your help
~Travis
Techno Isel Gantry III (?) base machine. EMC/LinuxCNC controller (Mesa 7i80HD-16).
about 48 X 48 X 5 inch working, Perske 3PH 5HP spindle
UCCNC 2017 Screenset
ok, thanks. I just plug my eBay Mach3 breakout into the UC100? (just to be sure, as it is a little pricey)
~Travis
Yes.
ok, last question (for now). if i decide to switch over to LinuxCNC, would it work on that? i don't see anything that jumps out at me that it will in the hardware list.
~Travis
No, it won't.
It only works with Mach3/4 or UCCNC.
Ok, thanks
~Travis
