Well I did some more research and found some info. I think I need to use the red and black for power and ground and then use A+ and B+. How do I determine which ones are A+ and B+?
I scored a CMC servo and need help with the encoder wiring. Here's the info:
Motor: CMC Mod.#ME3528-382C
Encoder: Digital Devices, Inc.
Model: M22DM2005LD50AS1
8 wires connected to a 9 pin connector:
Green
Brown
Orange
Yellow
White
Blue
Red
Black
Will this encoder work with a G320? If so, how do I wire it? If not, what is suggested for replacement.
CMC are usually
Green A
Brown /A
Orange B
Yellow /B
White Z
Blue /Z
Red +
Blk Com.
Thanks Al. What's the chance of this encoder working with the G320?
Is there a way for me to determine the resolution?
