Spindle speed optical sensor for Pokeys57cnc - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
Thread: Spindle speed optical sensor for Pokeys57cnc
  1. #41
    Oct 2016
    Default Re: Spindle speed optical sensor for Pokeys57cnc
    On the perfboard-that blue resistor is it a 100k? I can't see it so well
  2. #42
    Jul 2009
    Jim,
    Read the bottom of the post as I spoke too soon and am not quite there yet!
  3. #43
    Oct 2016
  4. #44
    Jul 2009
    Jim,
    The blue resistor is brown, violet, gray, black and measures 178 ohm.
  5. #45
    Jun 2010
    The generic 7414 Schmidt Trigger chip is widely used for interfacing, but most of the variants have quite a low drive capacity, and some do not get close to the rails. The version you need is the 74ACT14: that chip is the bees knees for interfacing as it can drive up to 24 mA each way. It is a plug-in replacement for the the other versions.
    Second thought: put all these 'interface' chips in good sockets. Servicing becomes so easy when you can flip a chip out and plug another in just like that. But CAUTION: when inserting an IC into holes or into a socket, make very sure that ALL the pins are going in. If a pin gets curled up under the chip it is impossible to see it, but the chip won't work as it should. I know ...
    Cheers
    Roger
