Power supply
Results 1 to 11 of 11
Thread: Power supply
    Apr 2004
    canada ontario
    Dec 2003
    Default Re: Power supply
    Looks basically OK, although there should be an inclusion in it for E-stop shut off.
    Apr 2004
    canada ontario
    Thanks Al now coming from a newbie to all this does the estop get wired inline on the white side. This is one of the components i did not look into. Thanks
    Dec 2003
    In the power side same as the fuse conductor, it is not normal to switch the neutral or usually necessary to also switch the N..
    Apr 2004
    canada ontario
    Thanks Al will do.
    Apr 2004
    canada ontario
    Power supply-20170317_220527_hdr-jpglayout so far. Im thinking motor connectors directly above drivers. And pp north of drivers. Still need estop.
  7. #7
    Apr 2004
    canada ontario
    Here is a pic with estop Power supply-20170318_144409_hdr-jpg
  8. #8
    Dec 2003
    That would work but usually it is incorporated with one that also shuts the spindle off.
    Apr 2004
    canada ontario
    I dont think ill control tbe spindle Al. Here is the estop switch, it has two sides the red and green do i connect straight through on the red or the green im a little co fused or second guessing myself.Power supply-20170318_202241_hdr-jpg
  10. #10
    Dec 2003
    Normally use the Red side it is N.C. that is the one you use, Green is N.O.
    Apr 2004
    canada ontario
    Thanks for your help Al. Here are some pics not done yet.
    Power supply-20170319_150958_hdr-jpgPower supply-20170319_151054_hdr-jpgPower supply-20170319_151106_hdr-jpgPower supply-20170319_164948_hdr-jpgPower supply-20170319_164948_hdr-jpgPower supply-20170319_150903_hdr-jpgPower supply-20170319_150931_hdr-jpgPower supply-20170319_165012_hdr-jpg
Power supply
Power supply
