Originally Posted by
KH0UJ
A raspberrypi + senseHAT module would be best for this project, you can control up to 64 NEMA 34 motors efficiently, program any servo motor at any RPM you want plus if you use senseHAT you can have a direct visual on the mini computer without the need to connect a monitor, you only need 4 LED`s on a single NEMA 34 motor, senseHAT has 192 LED output (RGB) fully programmable in anyway you want, you can even use a USB joystick to directly control the motors manually, like for example mode A first motor turns 4 RPM counter reverse or forward @ 360 degress or @ any rotation you want then switch to mode B which is 225 RPM and vice versa, or you can program it at full auto on all the motors with just a simple python script, every mode of operation needs a separate python script then link all the codes according to your preferences.
