Originally Posted by
CitizenOfDreams
Sorry, but you are quite wrong.
1. "on a VFD with a 240V output there is no way to change this" - yes there is. The output of the VFD can vary from 0 volts up to the line voltage. It is just a matter of changing the settings to run a motor of any nameplate voltage - 240V, 230V, 220V, 110V...
2. "the motor amps would be double to get the same performance as a 230v spindle, and this would make the input supply amps more than what he has available" - a VFD running a 110V 10A motor will draw roughly the same current as a VFD running a 220V 5A motor. A VFD is not a linear regulator, its efficiency stays more or less the same.
