They should all be at the Default setting, but they will have no affect on thisI dont understand Al what’s going on but the VFD is never left ON (without the PC and G540) since there is no reason to leave it ON. After a job is done the shut down order is:
Switch the VFD OFF
Switch the G540 OFF
Close Mach3
Switch the PC OFF
When I had the relays installed I never got the cnc going because at that time the wiring was in progress so I don’t know if this situation occurred.
However I do remember the following: when the time came to start the cnc for the first time I started the VFD alone to program it based on the parameters Mastec54 gave me. I remember this because I never used a VFD before and I was afraid to have the G540 / Mach3 ON at the same time. During this time I don’t remember the spindle was ON.
I have also changed the following parameters:
PD046 My setting = 04 (Stop), Default value = 14 (Reset)
PD047 My setting = 13 (E-stop), Default value = 22 (High Speed)
PD052 My setting = 01 (Run), Default value = 03 (Fault indication)
Is it possible that a parameter on the VFD creates this problem?
