Your numbers/results don't seem to add up, post your hookup or go to the Plitron site, Tech section and confirm that you have the full wave rect. schematic hooked up ok.
I would hook your Ground pin of your 13amp plug to the copper lug.
The white powder is electrons escaping .
OK, no it is just French chalk or this side of the pond I belive it is soap stone, just for friction reduction when the wire flexes.
Post your hookup!
