Your motor is hooked up like the drawing shows.
What fuse ? Is it on the input of the power supply or fuse between the power supply and driver ?
Are you testing one driver/motor at a time?
Test the power supply first with nothing hooked to the output, make sure it is the right voltage and then make sure the + - are correct to the driver + -.
You can try these tests, make sure the power is off before doing anything, also check to see that the power supply has no output voltage, capacitors in the power supply can hold a charge for a long time even will no power.
Safer to test one driver at a time if they are all hooked up ? , and also reduce the fuse size to half or less while testing.
If you unhook only the inputs on the driver (pul/dir/ena) and it doesnt blow the fuse, then its possibly a signal problem or configuration error, this would be rare but could make a fuse blow.
Next, power off/check for no voltage and unplug the motor from the driver and if it still blows the fuse when you power it up, your driver is bad. ( only the power supply connector on the driver is plugged in for this test )
