After reading carefully it does not seems that we can program the resolution so the parameter that should be given in number of step per mm in linuxcnc(emc2) should be 512 !
"http://www.youtube.com/watch?v=gK14SaaYMoc"]CNC laser galvo scanner head test - YouTube
A video with the AS5311 used to give the angle position . The device is clearly use off limit (in this case the magnet should be an arc !!! ) but the result is still pretty good.
This show the ease of use of such encoder !
