Results 1 to 3 of 3
Thread: writing G code
    Jan 2008
    New Zealand
    Default writing G code
    Hi all, I've been running a few test programs on Mach3 using the supplied wizards but want to write some simple G code programs myself.
    This may sound like a really dumb question but,
    Do you need software to do so or can you just sit down and type the code in like in a word document and then save it?
    Have tried that but when I try to load it into Mach3 it dissapears.
    Any ideas/suggestions??
    Cheers very much,
    Steve.
    Dec 2003
    Anything like WordPad should work, make sure it saves as ASCII text, no embedded codes.
    Also you can write and run it in a free simulator like
    http://www.cncsimulator.com/
    Jan 2008
    New Zealand
    Thanks Al, much appreciated,
    Steve
