So we bought a HUGONG Medium Industry CNC cutting machine with a HG611 controller, we manage our CAM things with FastCAM Pro but now we downloaded some art to cut and FastCAM reads it like a bunch of separated lines. I tried the overkill and join function in AutoCAD but nothing helps. What should I do?
P.S.: What CAM software are you using? And which is the best?
Hi Guys
I started my job at new firm and now I need to run Hugong Intecut 5. I ran the machine and cut some small parts. I am facing problem setting parameters for oxycut piercing. When I am running program made by FastCAM its not piercing into MS. Anyone would like to help to set Oxycut parameters? There was no parameters in Oxycut (flame cut) portion initially.
Hi Istra-Tim
I tried FastNest using DXF files and its worked fine for me. I dont like to waste time in FastCAM, instead working with AutoCAD dwg files, then export it to dxf and use in FastNest.
