From all the threads you are starting it looks like something is slowly mucking up windows.
It all started with the out of memory problem.
One of your programs has a memory leak. (doesn't free memory it allocated)
Reboot the computer, and make sure it is working properly, then go through and see if you can get past the out of memory problem.
Ex okuma lathe nut.
