- LEETRO gives ZERO customer support for controllers
I purchased a laser, including a Leetro controller, that supposedly includes Ethernet function. When you try to use the feature it fails.
Contacting leetro customer support, they state unless you purchased the controller directly from Leetro they will not support it. Problem is, most people receive these controllers as part of a larger system, and the manufacturer of the laser cannot support the controllers flaws.
I have had a number of problems with the controller MPC6585 and would NOT suggest it. The most frustrating behavior is the random hangups that leave the laser on and shining into the scrap below. I've had many ruined cuts and one nasty fire started because of this controllers bad behavior.
Avoid Leetro control equiptment!
- You may not post replies
- You may not edit your posts
Forum Rules
