Need help on buying CNC machine
Results 1 to 5 of 5
Thread: Need help on buying CNC machine
    Aug 2011
    Default Need help on buying CNC machine
    Hello,
    I am looking to get a new CNC machine. Looking on being able to work with wood turning and looking at about 18x40 or 18x48, as long as I am able tor turn 32" between centers. Geck 540 controller.
    I need a 4th axis. I have the spindle already, a Tekno 3140-C.
    Any suggestions please? I am even willing to work with somebody smaller that could build me something similar.
    Member awerby's Avatar
    Apr 2004
    Default Re: Need help on buying CNC machine
    Are you talking about a lathe or a router? Wood turning is done with a lathe, although you can make similar-looking parts using a 4th axis on a router. How big a diameter did you want on those 32" pieces?
    Aug 2011
    Quote Originally Posted by awerby View Post
    Hello Andrew,
    Router for sure with 4th axis. Something like this or similar:
    14" X 36" X 8" TRAVEL.
    (X) (Y) (Z)
    20MM UNSUPPORTED LINEAR SHAFTS ON THE Z AXIS.
    16MM SUPPORTED CYLINDER LINEAR RAILS ON X AND Y AXIS.
    X AXIS 1 QTY 5/8 DIAMETER LEADSCREW -- 2 STARTS, 1/4" TRAVEL PER TURN.
    Y AXIS 2 QTY 5/8 DIAMETER LEADSCREW -- 2 STARTS, 1/4" TRAVEL PER TURN.
    Z AXIS 1 QTY 1/2 DIAMETER LEADSCREW -- 2 STARTS, 1/5" TRAVEL PER TURN.
    DUAL EXTERIOR DRIVES ON Y AXIS.
    4 LEADSCREWS
    4 LEADSCREW NUTS
    4 NEMA 23 MOTOR MOUNT BLOCKS.
    4 HOME SWITCHES
    CONTROL BOX AND MOTORS (Gecko 540 or similar). I would be open to ClearPath motors as well
    4 AXIS STEPPER CONTROL BOX COMBO SYSTEM THAT WILL WORK WITH MACH 3.
    3 NEMA 23 400oz/in STEPPER (X AND DUAL Y)
    1 NEMA 23 400oz/in STEPPER (Z AXIS)
    4 HOME SWITCHES WIRED ON ALL AXIS. USE MACH3 TO ENABLE THE SOFT LIMITS FOR
    COLLISION CONTROL.
    1 BUILT IN RELAY FOR SPINDLE.
    Apr 2004
    I'm not sure what you're looking at there, but if it's set up like a conventional router, with the 4th axis assembly mounted on the bed, then the largest piece you'll be able to cut to the middle of will be about 5" in diameter, since the tool will stick out 2.5" and it needs some clearance. But that should be fine for pool cues.
    Aug 2011
    I cut usually 1.5" from square to round, sometimes 2" square and about 30 to 31" long. Finished size is about 0.845" to 1.250"
