Just print them on paper (with known X&Y positions) glue to material, make Gcode & cut with CNC.
Hi guys, I am willing to produce quick pieces of thin plywood (4mm) like this in the link which are given after each baptism. It seems that they have a sticker or are painted with color. I am wondering how can I produce such things using the cnc. If I have a printed by plotter sheet of these colorful designs, is there a way to glue it on the plywood and then cut the pieces according to the designs? I am not sure how these bonbons are produced. Is this a die cut product? Do you guys know?
Thanks in advance
:) Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
Don't use a glue with water is the probably answer. Spray contact cement should work.
