Diode Pulsed Solid State Laser source Fully Computerized control.
High speed and accuracy
High surface quality
Direct casting
Master models for rubber moulds
No lamp replacement (20000 hours of diode life)
No calibration
Specification of the machine:
Technical data:
Laser source: DPSS UV Laser 405nm
Scanning method: High Speed Galvo mirrors
Working area (x, y, z): 110 x 110 x 200 mm
Slice thickness*: 0.01 – 0.10 mm
Laser scanning speed: 0-4400 mm/sec
Software : Canux Controller
OS: Windows 7, WinXP
Input file format:
.stl - .slc, .mkr(DWSSystems format), gcode
Machine size: 380 x 515 x 733 mm
Weight: 50 Kg
Operating Temperature Range: 22-25°C
Operating Humidity Range: 60%
Electrical consumption: 400 W
Power supply: AC 230/115 V / 50-60 Hz
Standard accessories supplied with our machine:
No. 1 Building platform mm 120x120 (working area: mm 110x110)
No. 1 Resin tank.
No. 1 Set of handling tools
No. 1 Personal Computer with Touch Screen monitor(Built in machine)
No. 1 UPS 650VA 230V 50/60 Hz
No. 1 Canux Controller Software License
No. 1 MeshLib open source Software for STL Processing
Mesh Repair (module P02)
No. 1 User manual
if any question please mail me back..
thanks,
Himanshu Bhatt
