I have an x3 setup with servos. I have the 3 e-stops on the machine all setup through a c10 break out board. I was moving some cables around the other day, and had a runaway. The encoder cable had a cold solder joint which broke. The servo took off when I reset hit the switch, out of habit I went for the e-stop, which due to the way I have it wired did not stop the servo. So I had the opportunity to learn a new skill, how to reload a ball nut. Would I be better off running the e-stop through the gecko reset switch, which would at least disable the motor? I believe this would leave the motor coasting so it is not ideal. any help would be appreciated. Thanks, Tom |
| Straight from the Gecko site.. how to rig up a braking relay. http://www.geckodrive.com/upload/Ele...nicalEStop.pdf |
I use this exact setup with my gecko g320s. The only issue I had was I was burning through relays when the estop was hit. The sudden dump of power melted the contact in the relay. I was using a 15A relay. I ended up having to purchase a DC-DC 40A Solid State relay and Ive had trouble free estops and shutdowns ever since. AC rated relays will just burn up. |
| Thanks for the reply. That whole circuit thing isjust a bit over my head. If there is a spot where I could find a parts list and a and example of it being assembled sign me up. If not, where do you go to purchase something like that that just needs to be wired up. Thanks, Tom |
The GERC, It has the estop, relays and resistors already on a circuit board, and it provides several other handy features like enabling and disabling single drives and proper fault control. I believe they sell it in a kit where you have to source certain parts yourself or the entire thing ready to go. I have not bought this or even know how well it works, I just remember seeing it in my CNC travels and bookmarked it for future upgrades to my machine. Hope this helps! Good luck! |
| Need Help!- G320 - Setup problem, error voltage | MattTheNoob | Gecko Drives | 1 | 05-03-2009 09:35 AM |
| G320 Setup Help. | thosj | Gecko Drives | 1 | 04-21-2009 11:34 PM |
| Simple router mill e-stop setup? | dfro | General Electronics Discussion | 5 | 10-27-2008 03:42 PM |
| G320 Setup Electrocraft 60V Servos | Noah | Gecko Drives | 6 | 05-26-2004 02:55 PM |
| G320 Setup Electrocraft 60V Servos | Noah | Gecko Drives | 3 | 05-21-2004 10:37 PM |
