I am not currently using the disable pin on my Gecko 203v but I have a question concerning what happens when the disable pin is used. I have discovered that the stepper motor is held as soon as my DC supply is powered up thereby rendering manual movement of the axis impossible. My question is if the disable pin is pulled high, does it allow the motor to become freewheeling? Thanks in advance for your help. |
Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| Mike, Thanks for the reply. I did not see this in the manual. I am considering wiring a disable button for each axis so that I can use an edgefinder with the handwheels to set the DRO at the edge of a part. I know that this can be done in jog mode also but I thought that I would have better feel by hand. |
| hi Kae, From the manual, top of page 2 and here is the link. http://www.geckodrive.com/upload/G203V-REV-7-MANUAL.pdf Quote DISABLE PIN TERMINAL 7 Disable This terminal will force the winding currents to zero when tied to the step and direction controller +5V. The DISABLE input on the G203V is optically isolated and requires logic “1” to DISABLE and logic “0” to ENABLE the drive. Once it is disabled, the motor windings are unergenized and the motor freewheels. Unquote I had to read it again since they are so full of information that it is easy to over look exactly what you are looking for. Mike
| Mike, Many thanks! It appears that I need to read the manuals more closely. Since I need to add an E-stop, I could have the E-stop bring the disable pins high thereby allowing the motors to freewheel. I would kill two birds with one stone that way. Regards, Kent
| How to wire G203v disable connection with BB Estop circuit | Dale gribble | Gecko Drives | 3 | 12-21-2009 06:56 AM |
| How do I wire a G203v disable pin | Dale gribble | General Electronics Discussion | 0 | 12-21-2009 05:36 AM |
| Need Help!- How do you disable SMI? | SpeedsCustom | LinuxCNC (formerly EMC2) | 3 | 03-04-2009 03:22 PM |
| Need Help!- How to disable ac97sound? | Mr Bits | LinuxCNC (formerly EMC2) | 4 | 05-01-2008 05:25 PM |
| Need Help!- Disable FAPT F3T | Pxt | Fanuc | 1 | 02-27-2008 08:28 PM |
