Old 02-15-2010, 02:19 AM
Propaganda's Avatar
Propaganda is on a distinguished road
Quick G540 connection protection question.
I want to connect a cooling fan's ground terminal to the e-stop pin of the G540 so when the driver is out of fault (well, at least e-stop in 'ready' position) the cooling fan will be active.
The fan is 12vDC 330ma running off a dedicated PSU with a shared ground with the G540's PSU.
I just want to make sure the e-stop pin is protected in a way this will not harm the electronics.
tyty
"The whole world must learn of our peaceful ways... by force!" - Bender Bending Rodríguez
Old 02-15-2010, 05:30 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
You can purchase a double pole estop switch.
http://tinyurl.com/yfeos8b
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 02-15-2010, 10:59 AM
Propaganda's Avatar
Good solution. My e-switch is double pole but each pole is C-NC or C-NO. ...Just rechecked the link and it's the same config as mine so in that case the other pole would break the connection when in 'ready' position. Now, I can use a relay to flipflop the connection, unfortunately all my relays are 5v and I don't have the proper power resistor to power them from a 12v source. I guess I can use a automotive relay, they should be only about a few dollars found anywhere really.
But, I perfer the simplest solution at the moment.
Thanks.
Old 02-15-2010, 02:31 PM
jalessi's Avatar
Post
A DPST NC switch is available.
http://www.omron247.com/doc/pdfcatal.nsf/D062665A76A95A96862570C7007DA985/$FILE/D31A1650705.pdf
Quick question regarding G540 box... stombory Gecko Drives 7 11-02-2009 03:59 PM
computer connection question Larry Myers Controller & Computer Solutions 1 10-20-2009 05:50 PM
Question on board connection for spindle speed gn3dr Syil Products 3 03-13-2009 01:20 PM
Gecko G540 Quick question mad_dog096 DIY-CNC Router Table Machines 0 01-02-2009 09:06 PM
Interact w/T151 control PC connection question rkdygert Bridgeport and Hardinge Mills 16 03-22-2007 09:00 PM
