What is the correct size fuse to use on the AC side to protect the G540 in a controller box? My IEC plug had a 1.5 amp 250 volt fuse which was fine powering up the power supply but once I hooked up the G540 and turned the power on, the fuse blew. I rechecked my wiring. Everything was correct. I disconnected the G540, replaced the fuse, powered on the power supply all was fine again. Replaced the fuse again (same 1.5A rating), reconnected the G540 and blew the fuse again when I powered up the box... Is the 1.5 amp fuse too small? Its an old computer SCSI drive case... |
http://www.homanndesigns.com/EN010_V8.pdf ![]() Last edited by tulsaturbo; 02-06-2010 at 07:06 AM. Reason: added image |
| Tulsaturbo The fuse should be at least 6.5 amp if you are connecting to 120 volts A.C. The 1.5 amp fuse is far to small. Your wiring looks fine. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| Material to cut plug from? | sco | Australia, New Zealand Club house | 13 | 06-12-2008 04:21 PM |
| Ready to use and plug | Kelinginc | Automation Technology Products | 6 | 04-05-2008 11:25 PM |
| Cadkey Plug-in | LYN BYRD | Cadkey / KeyCreator | 5 | 09-14-2007 09:01 PM |
| CNC kit ?(Plug n' Play) | rhupin | Open Source CNC Machine Designs | 4 | 01-18-2007 01:51 PM |
| IMservice plug | CNCadmin | CNCzone Club House | 0 | 11-24-2004 12:18 PM |
